Duct Disconnected In Hard To Reach Area - HVAC - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 04:22 PM   #1
Duct Disconnected in hard to reach area
There was hot air coming from one of my vents so I went up to the attic and could feel cool air coming from the area it was in. I am assuming the ductwork has been disconnected somehow. The only problem: it is in an area I cannot get to. How would I go about fixing this?
needhelp06 is offline   Reply With Quote
Old 08-18-2010, 05:10 PM   #2
An old Tradesmen
Rewards Points: 6,132
Figure out how they ran it there. And then access it that way.
The Following User Says Thank You to beenthere For This Useful Post:
COLDIRON (08-19-2010)
Old 08-18-2010, 05:13 PM   #3
Rewards Points: 1,214
You have to get to it somehow.
COLDIRON is offline   Reply With Quote
Old 08-18-2010, 06:22 PM   #4
Swimming in attic insulation,ahh the joys of summer. Lots of folks would rather pay for that to be done rather then DIY.
Old 08-18-2010, 06:42 PM   #5
An old Tradesmen
Yep. Nothing like being itchy all day after working in an attic.
Old 08-19-2010, 12:41 AM   #6
No, it's a very simple DIY project
gena is offline   Reply With Quote
Old 08-19-2010, 07:05 AM   #7
I hate the insulation and the little pointy roofing nails that I have bumped my head into about 1000 times.
Have fun or wait till the weather changes soon. Still itches and nails but don't seem as bad.
Old 08-20-2010, 11:40 AM   #8
update
I went back up in the attic and took a picture. see attached. I see no way to get in there. how else can this be fixed? how would an professional even do it?
Old 08-20-2010, 11:44 AM   #9
by the way. the ductwork in the picture is going away from the HVAC into a room with a raised ceiling. 1 is the return air duct, and the other has not reached the register yet. from that register, 1 duct is connected properly, and the other isn't ( i only know this because hot air comes from one vent, and cold from the other).
Old 08-20-2010, 12:01 PM   #10
fabrk8r
fabrk8r's Avatar
Is it disconnected at the register or at a joint further away from the register?
If it's just disconnected from the register you may be able to remove the register, reach in and pull the flex out enough to reattach it to the register and push the register back into the opening and refasten it.
There is kind of a special technique used to attach flexible wiremold flex duct to keep it from coming loose.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-20-2010, 12:06 PM   #11
fabrk8r
fabrk8r's Avatar
Just to clarify...are you saying the supply duct that is disconnected is supposed to be supplying 2 registers, but only one supply register has cold air coming out and the return register is connected and working properly?
Old 08-20-2010, 02:04 PM   #12
The installers had to hook up the flex first then pull it back. You'll need to do the same thing or cut the ceiling to work from below.
Old 08-20-2010, 04:52 PM   #13
An old Tradesmen
Might have to unconnect some of what is there. To get in to reconnect the flex.
It bites. But thats what the architect and builder left the HVAC sub to work with.
Old 08-25-2010, 02:05 PM   #14
the duct on the left keeps going then connects to two other ducts (i dont know the right terminology). one of those two is connected property and blows cold air. the other is disconnected. [the duct on the right in the pic is return air]
Old 08-25-2010, 02:08 PM   #15
the left duct goes from the HVAC to past where the picture was taken with no breaks. it is about 20 ft. of duct that i can see...so i don't see anywhere i can disconnect to give me space. could i cut the duct in 2 so i can more part of it out of the way...crawl back to fix the problem...then reconnect what i cut with a joint? or are ducts not able to be cut and reconnected?
Tags
attic , duct work , hvac , vents
Return Air Vents stubits HVAC 149 04-21-2010 05:50 PM
flex duct termination issue LanterDan HVAC 2 02-12-2009 06:59 AM
duct work framing kama Carpentry 4 11-15-2008 01:40 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
