Duct Design - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2007, 10:18 AM   #1
Duct Design
I plan on putting a wood furnace in my work shop. I would like to have a main trunk line run down the center with registers on the trunk line. What I need are design rules for the trunk line so I can determine the sizing requirements. The shop is L shaped with 2820 sq. ft., 12 ft wall clear span construction with a 16 foot peak. Thanks for any information that you can supply.
kaldeh is offline   Reply With Quote
Old 12-11-2007, 04:59 PM   #2
30 year tech
hvac122's Avatar
The duct would be designed by the fan CFM and the desired static pressure. What would these figures be?
hvac122 is offline   Reply With Quote
Old 12-11-2007, 10:34 PM   #3
The CFM is advertised as a 3 speed fan 1150,1500 and 1800 CFM. The static pressure is unknown at this time, I will have to request that information from the vendor. The furnace is the Fire Chief and can be found at http://www.victoriansales.com/firechiefhome.html. Thanks for the response.
Tapping into existing metal duct Mike_Atlanta HVAC 1 11-30-2007 01:07 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
