Duct Decision - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2014, 11:03 AM   #1
Rewards Points: 54
Duct decision
Current situation is old metal duct that needs cleaning inside (assumption), old insulation removed, sealed up and reinsulated.
3 rooms are supplied with what appears to be 7 inch metal duct, 1 is a 6 inch and 1 that is either a 9 or 10 inch that supplies 2 bedrooms.
So although a lot of work, having cleaned, old insulation removed, ducts sealed and insulation replaced is all doable.
Having said that, since these are for the most part short runs and straight, should I just go back with quality flex?
More questions I am sure!
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 06-27-2014, 04:44 AM   #2
An old Tradesmen
Rewards Points: 6,846
No harm in using flex. May have to go to the next size bigger flex to get the same amount of air flow.
The Following User Says Thank You to beenthere For This Useful Post:
digitalplumber (06-27-2014)
Old 07-14-2014, 08:07 PM   #3
Rewards Points: 54
ok IF I have a roll of duct insulation and it is 48" wide x 25 feet long, do I cut the insulation in 4 foot width pieces by the diameter length or do I cut for the total length of the duct and then cut that piece for the diameter?
Dumb question I know
Also, should the new stuff be glued on??
Old 07-14-2014, 09:26 PM   #4
Rewards Points: 380
I would say depends on how straight the run is. If you have elbows to work around you definitely do not want 1 long piece. If you only have to go 10' all in one straight run then I would do it all at once, less joints is better for preventing air and thus condensation coming in contact with your old duct and new insulation. Just my opinion.
HVACDave is offline   Reply With Quote
The Following User Says Thank You to HVACDave For This Useful Post:
digitalplumber (07-15-2014)
Old 07-15-2014, 04:50 AM   #5
An old Tradesmen
Generally, you cut it by the roll width. So if doing a 7" pipe, you would cut a 24" length of the 4' roll.
Old 07-15-2014, 05:46 AM   #6
Rewards Points: 54
any glue used?
Old 07-15-2014, 04:25 PM   #7
An old Tradesmen
You can spray glue if you want. But just stapling it is common, and then tape the joint.
Bath fan duct questions metazone Kitchen & Bath Remodeling 6 12-27-2013 08:18 PM
Doing a dryer duct, the right way... nowwhatnapster HVAC 7 01-30-2013 07:52 PM
My Duct Sealing Project Cakemeister HVAC 6 06-13-2011 11:45 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
