Duct & Cold Air Return? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 09:32 PM   #1
Duct & cold air return?
Building a slab on grade home. Was wondering if any heat and AC units are made to push the heat through the cold air return vent beings they are close to the floor and then when the AC is on reverse the blower to push cold air out the ceiling vents? Thnks
Timnenji is offline   Reply With Quote
Old 09-21-2013, 10:20 PM   #2
An old Tradesmen
Rewards Points: 7,826
No, none are made like that.
Old 09-22-2013, 08:52 AM   #3
Rewards Points: 314
and the reason for that is that a well designed system will mix the air in the room(s) for the various seasons. be sure your designer uses manual j and manual d for the design of your new homes hvac. If it was me I would do a lot of homework on ducts (types, sealing, fittings etc) to make sure your system is designed and installed well.
bobinphx is offline   Reply With Quote
The Following User Says Thank You to bobinphx For This Useful Post:
Timnenji (10-06-2013)
How to use fiberboard as a duct return Scooby333 HVAC 1 03-17-2013 04:29 PM
Help with return air duct gasbie HVAC 4 06-20-2011 06:54 PM
Converting wall cavity to cold air return - wiring questions hockeyslasher41 Electrical 0 06-14-2011 10:11 AM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 10:54 PM
