In-Duct Booster Fan Power Source Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 09:16 AM   #1
In-Duct booster fan power source question
I have a room on the outside of the main house that has two in-duct booster fans to get a little more air in there. The contractor hooked each of these fans up to a always on AC source. So they were running 24x7 since being wired in about 5-6 years ago. They are now both dead - presumably burned out.
I purchased two replacement fans. Before I install them I need to provide a switched power source so that they are only running when the furnace is running - which I am hoping will greatly extend their life.
I have a Comfortmaker Model C8MPN100F14B1. I read in other posts that I could hook a relay to the EAC connector and have it trigger the fans. I looked on the circuit board of the system and I see markings for EAC but it looks like there is no connector. I do see what looks like a relay on the board next to it that has NO and NC connections that are open. Please see pictures attached.
If this does not work then I am guessing that I can install a duct stat and have that trigger the fans?
Any help would be appreciated. Thanks.
In-Duct booster fan power source question-2012-11-27-19.02.20.jpg   In-Duct booster fan power source question-2012-11-27-19.03.20.jpg
simonmason is offline   Reply With Quote
Old 11-28-2012, 05:01 PM   #2
An old Tradesmen
Rewards Points: 6,112
Use a sail switch, or if you don't have A/C a duct stat will work.
Old 11-28-2012, 05:40 PM   #3
Items wanted: Time
Rewards Points: 150
I'd use a current sensing relay on blower common.
NiNe O is offline   Reply With Quote
Booster Fan Inline With Furnace Duct dstorjoh HVAC 9 02-13-2012 11:16 AM
Source of supplemental power for residential... nexusteve Electrical 3 09-26-2011 01:51 PM
DC power cord question Wims2205 Electrical 13 06-29-2010 11:00 PM
need power source badluck Electrical 2 08-05-2009 04:44 AM
Undercabinet lighting power source? Ideas? PDubs Electrical 7 01-28-2009 05:37 AM
