-   -   In-Duct booster fan power source question (http://www.diychatroom.com/f17/duct-booster-fan-power-source-question-164964/)
simonmason 11-28-2012 08:16 AM
2 Attachment(s)
I have a room on the outside of the main house that has two in-duct booster fans to get a little more air in there. The contractor hooked each of these fans up to a always on AC source. So they were running 24x7 since being wired in about 5-6 years ago. They are now both dead - presumably burned out.
I purchased two replacement fans. Before I install them I need to provide a switched power source so that they are only running when the furnace is running - which I am hoping will greatly extend their life.
I have a Comfortmaker Model C8MPN100F14B1. I read in other posts that I could hook a relay to the EAC connector and have it trigger the fans. I looked on the circuit board of the system and I see markings for EAC but it looks like there is no connector. I do see what looks like a relay on the board next to it that has NO and NC connections that are open. Please see pictures attached.
If this does not work then I am guessing that I can install a duct stat and have that trigger the fans?
Any help would be appreciated. Thanks.
beenthere 11-28-2012 04:01 PM
Use a sail switch, or if you don't have A/C a duct stat will work.
NiNe O 11-28-2012 04:40 PM
I'd use a current sensing relay on blower common.
