Duct Board Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 09:32 AM   #1
duct board plenum
Hi I am building a cottage and installing a Rheem air handler. The package included duct board plenums for supply and return. Plenums are pre-cut. The air handler came with 1" flanges for the supply and return. How do I attach the duct board plenums to the air handler?
hoboat is offline   Reply With Quote
Old 05-29-2012, 09:42 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
UL listed Aluminum Foil Tape.
You can also use Mastik Hardcast but it can be messy. It's kind of a putty like goop that dries up rock hard. For diy'er, use this tape. Legal and to code and clean.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-29-2012, 09:56 AM   #3
Thanks - do I attach the plenums right to the air handler and tape the joint? Or does there need to be some sort of sheet metal transition between the air handler and the duct board plenum?
Old 05-29-2012, 10:03 AM   #4
Butted directly to one another, no joint needed. Good idea to prop up the far end of the plenum with some bricks or 2 x 4's and leave them there. Level it out to make the job easy and to lessen any stress gravity will put on it, especially with ducts attached.
Thanks.
Old 05-29-2012, 10:07 AM   #5
Thanks.
Old 05-29-2012, 10:10 AM   #6
Don't shy from using two or three strips of tape to completely seal each side, making the entire strip wide so it grips the duct board and the air handler really well.
If you have a squeegee to rub the tape down it would be best, really pushing down on it.
Thanks.
Old 09-24-2012, 09:18 PM   #7
I have the ductboard supply plenum in place. It is 48" long. Does it matter where I put the start collars? Do they need to be near the end of the plenum farthest from the air handler? Can they be close to the air handler? Or does it matter where the start collars are cut in?
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Sealing air return duct jd1979 HVAC 8 10-07-2010 08:46 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 06:22 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
