Ducanes Fires Up Goes Out - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 01:15 PM   #1
Ducanes fires up goes out
My Ducane furnace ignites the pilot and fires up the four gas chambers. The flame stays on for 3-4 seconds and shuts off. Of course the motor for the fan has not had a chance to come on yet. The gas ignitor/burners continue to cycle on and off this way. This is while set on Auto. Now when I turn the thermostat to Fan, the blowers work and it is blowing out air and the pilot ignites the gas burners and it stays on for 3 seconds, and then shuts off. Just like it does on Auto. It seems as if all aspects of the furnace work but something is not communicating. It doesn't seem as if any limit switch would know to shut the burners off in as little as three seconds? Does anyone have an idea?
Thisbe
thisbe is offline   Reply With Quote
Old 03-01-2009, 01:22 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 380
If it is an older Ducane with a Honeywell Smart Valve SV**** best to call a servicetech. The newer Ducanes have a flame sensor which sits in front of one of the burners and you can remove and clean it (not easy to get at) with fine emory paper. Should look like this one:
Old 03-01-2009, 01:33 PM   #3
define old ducane? This one was installed in 2000. Thanks for your reply!
Old 03-01-2009, 01:52 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Most of the time it is hard to determine the age without having the model and serial number posted.
So, it should have a flame sensor, remove it, clean it with emery cloth, steel wool or fine sand paper. Wipe it clean with a cotton cloth and don't touch it (the rod) with your fingers after you clean it due to the oils on your hands will contaminate it. Reinstall and wow it works
Good luck
Old 03-01-2009, 03:42 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 380
I used to install them and in about 2005 they went with the better independant flame sensor and ditched the troublesome Smartvalve system. If the gas valve says SV8500 M or H that unit does not have a flame sensor which can be cleaned without breaking the HSI.
Old 03-01-2009, 05:19 PM   #6
HVAC / Plumbing
Smart valves ???? I like direct spark ignition
kenmac is offline   Reply With Quote
Old 03-01-2009, 06:19 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 380
There was nothing smart or good about the "idiot" valve. Rheem has a nice spark ignition.
Old 03-01-2009, 06:33 PM   #8
HVAC / Plumbing
Idiot valve is good . I always called them the dumb valve
Old 03-01-2009, 08:16 PM   #9
thanks everybody. i wish you were here to fix it. i was not able to fix it by myself, but have a good notion of what the problem is thanks to you all and won't sound like a dumb myself when I call in the repair. May save me money too.
thanks thisbe
Old 03-01-2009, 08:24 PM   #10
HVAC / Plumbing
very good chance that smart valve has had a stroke . To say I hate those valves is an under statment
Good luck
Heil 80% EFF--- Fires, runs, Shuts off!! mrfyvie HVAC 4 02-09-2009 10:21 PM
Boiler heater blowing black soot when it fires rickeyraye HVAC 2 01-06-2009 08:36 PM
Blower Fires Up But No Heat, just Cold Air amyco33 HVAC 4 04-13-2008 07:33 PM
boiler fires but no heat janhuge HVAC 1 11-09-2007 04:52 PM
