DUCANE Mod#mpga075b3 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 09:32 AM   #1
DUCANE mod#mpga075b3
the heater turns on but the blower fan doesn't
Eddie494540 is offline   Reply With Quote
Old 12-28-2011, 11:07 AM   #2
well, with that very limited information.......I would say you have a bad HFR (heater fan relay)
harleyrider is offline   Reply With Quote
Old 12-28-2011, 11:23 AM   #3
how
Rewards Points: 1,104
So many possibilities with so little facts. Last month, I found non functioning blower and a squirrells nest filled with furnace wire.
how is offline   Reply With Quote
Old 12-28-2011, 03:36 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
Or my favorite one where Joe homeowner installs a new airfilter w/o removing the plastic wrapper which covered 1/2 of it. wonder Y it didn't seem to heat very well.
Old 12-28-2011, 09:33 PM   #5
Houston204's Avatar
Rewards Points: 556
Houston204 is offline   Reply With Quote
Old 07-03-2013, 09:34 PM   #6
System not doing anything
My unit will not say anything or do anything. A fuse was replaced last time, which I did and its not saying anything. Someone please help me solve this....
carlos92310 is offline   Reply With Quote
Old 07-04-2013, 03:30 PM   #7
An old Tradesmen
Rewards Points: 6,906
Did you check the breaker in the panel box.
Old 07-05-2013, 06:18 AM   #8
biggles's Avatar
fan limit disc or Honeywell limiting dial or the motor is shot note fan cycles on from the heating burn not the stat
95% ducane furnace peanutt710 HVAC 1 12-08-2010 12:31 PM
I am having a problem with a Ducane CG95TC furnace. jesseflamme HVAC 5 12-07-2010 09:26 PM
DUCANE HEATER, led blinking red 3 times tom356 HVAC 1 09-04-2010 05:47 PM
Ducane gas furnace problem rugger HVAC 4 04-10-2009 07:01 AM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 06:44 PM
