Ducane Hot AIr Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 05:52 PM   #1
I have a Ducane hot air furnace and it keeps cycling on and off every few minutes. I have replaced the t-stadt and it stopped for a few weeks but it started doing it again last night. Please help! How can this be fixed?
neraised is offline   Reply With Quote
Old 02-20-2010, 06:02 PM   #2
Is your filter clean?
Is the main circulator fan staying on the whole time, or is the entire furnace going on and off?
Are the burners turning on and then off rather quickly? If so have you tried cleaning the flame sensor?
Giianee is offline   Reply With Quote
Old 02-21-2010, 11:06 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
need more info
plummen is offline   Reply With Quote
Old 02-21-2010, 12:42 PM   #4
Licensed Master Plumber
Check the amperage at the thermostat and make sure the anticipator is set at the controls recommendation. Or, your control may be bad as in weak relay or transformer or perhaps a loose wire. Check the obvious first, like loose wires, but if you say it stopped for awhile when you changed thermostats I would suspect that you didn't set the heat anticipator amps on the new one and burned it out.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-22-2010, 06:00 PM   #5
I second that
SULTINI is offline   Reply With Quote
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 04:14 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 06:44 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
