Ducane Gas Furnace Fan Speed Change - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 08:02 AM   #1
ducane gas furnace fan speed change
what leads do i switch on circuit board?
homebound479 is offline   Reply With Quote
Old 09-30-2010, 08:08 AM   #2
HVAC / Plumbing
look on the board. It will show low, med, high,Etc... large wires, red, blue black ,etc,
kenmac is offline   Reply With Quote
Old 09-30-2010, 04:13 PM   #3
Rewards Points: 460
Post
Often the schematic for wiring is on back of furnace cover(s).
And, the wires themselves can be labelled. Low/Low Medium/High Medium/High are my choices I believe. The unused wires will be of same gauge and should be capped. If you increase existing speed to a higher speed, by swapping wires, you may find it's noisier at the registers.
To experts on DIYChatroom/HVAC: 1) Does increasing blower speed get rooms warmer quicker? More circulation? 2) Is it true that if motor windings burn out on one speed of a multi-speed fan motor, by switching to another speed you will have a motor with new life (assumed maintained in all other ways)?
diyorpay is offline   Reply With Quote
Old 09-30-2010, 06:03 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
1) Increasing speed gets more air to farther away rooms but does not do it faster. Furnace can only produce a constant amount of BTUs. Speeding the fan up gives cooler but more air.
2) No. If the motor is overheated or one winding cooked it is in such bad shape it will die soon.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
variable speed furnace mjricemonica HVAC 5 03-25-2010 01:38 PM
Honeywell minizone compatiability with variable speed furnace rucy HVAC 13 12-16-2009 12:13 PM
ducane furnace MPGA100B4B mas382 HVAC 1 08-16-2009 08:50 AM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
