Ducane Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 06:17 AM   #1
Ducane gas furnace
My 30 yr. old gas furnace has a cracked heat exchanger so it's time to replace it. I called an hvac contractor & he recommended a Ducane with a 95% efficiency rating. I think he said Ducane is made by Lennox. Is that true & does anyone have an opinion on the Ducane brand? The contactor said he's installed 10 of these in the past year with no problems, but I realize that could be a sales pitch. Thanx.
dfg712 is offline   Reply With Quote
Old 10-19-2012, 09:58 AM   #2
Rewards Points: 13,300
Make some more calls and get some more quotes.
And yes it's time for that old one to go.
Old 10-19-2012, 10:27 AM   #3
Are you saying stay away from Ducane?
Old 10-19-2012, 03:02 PM   #4
Rewards Points: 610
I have had to have our service contractor (when I worked for a very large land holding company) to replace at least 20 heat exchangers in oil fired furnaces that had Ducane heat exchangers in them. After a few we just decided to go with new furnaces. The same contractor related to me about a new subdivision where about a hundred heat exchangers, in gas fired furnaces, also Ducane heat exchangers, had cracked...these were all only one to two years old at the time but, that was about 20 years ago so, not sure how they have been standing up lately.
Check around AND ask about warranties, including labor.
If Lennox bought them out probably much better now.
techpappy is offline   Reply With Quote
Old 10-20-2012, 12:45 PM   #5
funfool's Avatar
Rewards Points: 534
This kind of surprises me they suggested Ducane.
I bought a used Ducane furnace, is a 2001 model, it sat in storage about 3 years before I finally got it installed and working with help from here, 2 weeks ago.
I live in New Mexico, mild winters, the burners still look like new.
I was worried about the electronics on it after sitting for 3 years, so far it works perfect and pleased with it.
When I bought it 2 years ago, I did some research on it, were good and bad reports.
But lennox did buy them out, when I search for Ducane, all they make anymore is gas bbq's.
Maybe if you search lennox you can find the Ducane brand?
funfool is offline   Reply With Quote
ducane gas furnace ignitor glows but no flame mainman HVAC 1 12-21-2010 06:39 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
Ducane gas furnace problem rugger HVAC 4 04-10-2009 08:01 AM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 07:44 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
