Ducane Furnace Will Not Fire Up - HVAC - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 10:28 AM   #1
Ducane Furnace will not fire up
I have a Ducane gas furnace (Model-MPGA125A5). I have been experiencing problems with it lighting. Occasionaly, the vent fan would kick on, but then nothing would happen. At first, tapping on the gas head would cause the unit to fire up. The problem has become more frequent, and I have found that if I jiggle the 4 wire connector on the side of the head, that the unit would fire up.
Before I go and order a gas head, I wanted to make sure that this was where the problem was?
jdaily is offline   Reply With Quote
Old 02-11-2010, 07:39 PM   #2
HVAC Tech/ Browns Fan
It a Smart gas valve and it will cost big bucks. I may check pressure switch tube and take paper clip into the bar fitting on draft motor. The flame sensor maybe dirty too but good luck cleaning it most the time I just replace it due to not breaking the glow plug.
Tator1076 is offline   Reply With Quote
Old 02-11-2010, 08:06 PM   #3
Follow up question to tator
What is your recommended method to test the pressure switch tube?
Old 02-11-2010, 11:00 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
pull the hose from the inducer housing and suck on it,if its working youll here it click inside
plummen is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 07:44 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
