Old 01-09-2011, 06:41 PM   #1
ldr
Ducane Furnace Problem
Installed a new Ducane 95% condensing gas furnace. The unit will run and cycle for five minutes before shutting down. The units board flashes 3times which indicates a bad pressure switch. I changed the pressure switch and still have the same problem. The gas company says there is good pressure in the line.
ldr is offline   Reply With Quote
Old 01-09-2011, 06:59 PM   #2
Sounds like a venting issue.
Old 01-09-2011, 07:24 PM   #3
ldr
Vented with 3 inch pvc to the outside through a sidewall about 11 feet total run with 4 elbows. Same for the intake.
Old 01-09-2011, 07:40 PM   #4
Professional
is there slope (1/4" per foot) all the way back to the furnace? ensure there is no debris in pressure port on draft motor
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-09-2011, 10:50 PM   #5
Home Air Direct's Avatar
Is it one of the new 33" furnaces? I have had contractors that did not follow the instructions for the new external condensate drain and they have had lockouts. The instructions are very specific on these.
Good luck.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
The Following User Says Thank You to Home Air Direct For This Useful Post:
ldr (01-10-2011)
Old 01-10-2011, 09:17 AM   #6
ldr
Good luck.
are you referring to the condensate trap drain or something in addition to this?
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 05:38 PM
Another Keeprite Electric furnace problem lrad Electrical 0 10-18-2010 01:24 PM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 07:44 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 11:30 AM
