Old 10-31-2010, 09:31 PM   #1
ducane furnace model cmpb100caa does nothing, light on gas valve indicates all ok
ducane furnace model cmpb100caa does nothing. Any ideas?
daveandoliver is offline   Reply With Quote
Old 10-31-2010, 10:44 PM   #2
HVAC / Plumbing
Smart valve ?
kenmac is offline   Reply With Quote
Old 11-02-2010, 09:49 AM   #3
still need help asap hi:limits are all closed.air switch is closed and will open when you blow into hose.door switch is working ok.there is 120v at transformer terminals on board and 24v at t-stat terminals.light is flashing on gas valve there is no fault lights on board.could board be bad.any recomendations?
Old 11-02-2010, 02:55 PM   #4
HVAC / Plumbing
Your unit may have smart valve
http://www.transtaracsupply.com/pdf/sv95control.pdf
Old 11-02-2010, 08:40 PM   #5
An old Tradesmen
The pressure switch is closed without the inducer running?
Old 11-06-2010, 09:36 AM   #6
Thanks for help.Retested all componets again and again"about to give up but finaly found short in t-stat wires.Replaced wires then found board bad.Replaced board and unit is working ok now.
Changed gas ball valve and York furnace won't fire, please help. philsoldat HVAC 35 11-03-2010 12:12 PM
Furnace Ignitor Was Clicking While Lit, Now Won't Light scribb HVAC 13 10-12-2009 02:00 AM
Ducane gas furnace problem rugger HVAC 4 04-10-2009 08:01 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
bryant furnace will not light somany?'s HVAC 16 11-29-2006 09:28 PM
