Ducane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2008, 01:59 PM   #1
ducane furnace
I have a ducane furnace its about 2 yrs old when it is really cold out the furnace is unable to maintain temperature it will shut off and will not restart without going to the thermostat and turning it off and on again. This usually happens in the middle of the night when it is the coldest and only on really cold days. I have waited to see if it would turn on again but it doesn't do it on its own. The filter is clean and all of the vents are fully opened and working. We had this problem last year and called someone to service it they fixed it but now it is doing the same thing can anyone offer some advice?
shieldsjw is offline   Reply With Quote
Old 12-22-2008, 03:22 PM   #2
What was done last year to fix the problem? What do you mean by 'going to the thermostat and turning it off and on again' somehow resets gets it working again.
dac122 is offline   Reply With Quote
Old 12-22-2008, 03:52 PM   #3
If you have an ac coil, check it to make sure it is not dirty.
SKIP4661 is offline   Reply With Quote
Ducane Furnace - no heat dave_in_waterloo HVAC 4 09-19-2012 10:41 PM
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 05:14 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
