Ducand Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 12:34 PM   #1
ducand furnace
the unit fan comes on the the ignites and the the burners go out after about 3-5 seconds and then cold air after about 2 mins the burners ingite again for 3-5 seconds and out again this cycle goes on non stop and the fan stays on and the house is getting colder any ideas?
wintrow105 is offline   Reply With Quote
Old 11-15-2008, 02:52 PM   #2
clean the flame sensor with fine sandpaper or steel wool its located below the burners usually with a single wire going to it its a silver rod with a porcelain end also when the flames are burning they have to engulf the flame sensor completely the f/s gets a fine coating built up on it and creates shortcycleing conditions very common repair
kennzz05 is offline   Reply With Quote
Old 11-17-2008, 07:22 AM   #3
Yes, check the simplest things first. If that doesn't do it then post back with specifics such as efficiency of furnace.
dac122 is offline   Reply With Quote
Old 11-17-2008, 10:11 AM   #4
30 year tech
hvac122's Avatar
Most manufactures recommend cleaning a flame sensor with scotchbrite or a dollar bill. Not supposed to use sandpaper.
hvac122 is offline   Reply With Quote
