Dual Thermostats - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 01:13 PM   #1
Dual Thermostats
There is a thermostat upstairs and downstairs. How is the most efficient way to set the thermostats? When the one downstairs is turned off it stays comfortable but is that overworking the system by using only the upstairs?
13711 is offline   Reply With Quote
Old 05-29-2013, 05:14 PM   #2
Rewards Points: 40
Hi there,
We need much more information than that.. What kind of HVAC system do you have?
I don't fully understand your question. Like any machine, the more you use it, the more stress is out on it. However, having idle units is not ideal either. I think good discernment should govern that for anything.
However, if you could be more specific, that would be better!
Cam
CamaLamaDD is offline   Reply With Quote
Old 05-29-2013, 09:13 PM   #3
An old Tradesmen
Rewards Points: 7,404
A/Cs are designed to be able to run 24/7 with no harm done to them.
Using Two Thermostats Question tim2255 HVAC 9 01-03-2012 10:13 PM
Questions about dual stage thermostats qoncept HVAC 9 12-26-2011 11:49 AM
Dual Stage Furnace grod777 HVAC 34 11-05-2011 10:28 AM
Lutron Thermostats ChrisDIY HVAC 4 10-24-2011 08:45 AM
Dual Thermostats soccermom22 Plumbing 2 02-11-2008 09:58 PM
