Dual Stage Furnace - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 11:09 AM   #31
raylo32's Avatar
Rewards Points: 1,218
I have a 3M-50 and, yes, it does allow you to adjust diff and swing pretty easily. I have my swing set for 1 deg and diff set for 4 deg (default is 2 and max is 4.5 IIRC).
raylo32 is online now   Reply With Quote
Old 11-05-2011, 11:20 AM   #32
Rewards Points: 95
The only thing I don't like about the 3M-50 is that the wires are visible on top, but I will try and find a way to cover them.
I actually have a question regarding my t-stat. In the setup it has 2 steps that state:
Stage 1 Heat Cycle rate (CPH: cycles/hour)
0=For gas and oil furnaces of less than 90% efficiency
1=For steam or gravity systems
3=for hot water systems & furnaces of over 90% effciency
9=for electric furnaces
Stage 1 Heat Cycle rate/Aux heat cycle rate (CPH: cycles/hour)
Options are Same as above
Other cycle rate options are 2,4,6,7,8,10,11,12
there is also an option for the A/C compressor also-default is set at 3.
How do I determine the efficiency on my furnace and what would be the difference if I change it from 0 to 3?
grod777 is offline   Reply With Quote
Old 11-05-2011, 11:25 AM   #33
raylo32's Avatar
No wires visible on top of my 3M50. It has a trim cover that totally hides the wires.
Does your furnace have a metal exhaust pipe or PVC? If PVC it is >90%.
Old 11-05-2011, 11:27 AM   #34
Rewards Points: 95
If it has a cover now-awesome-SOLD.
It has a metal exhaust. So the default of 0 is good?
What about the A/C compressor?
Old 11-05-2011, 11:28 AM   #35
An old Tradesmen
Rewards Points: 6,068
Originally Posted by grod777 View Post
Ok. 2.5 minutes is good I would say.
Should be plenty. Adjust to less, if you get cold air blowing out.
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 09:45 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
