Drywall Over Thermopan - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 08:43 PM   #1
Drywall over thermopan
I am finishing my basement and we are going to be drywalling right to the floor joists. My question is whether I should remove the thermopan for the cold air returns or leave it in place. I am worried if I leave it in place you will see it after the drywall is up. Thanks for the help in advance.
TimothyDIY is offline   Reply With Quote
Old 07-01-2012, 10:30 PM   #2
Tear it out if you want. Make sure to run a bead of caulk on the floor joist so there's a good seal to the drywall.
Old 07-02-2012, 09:26 AM   #3
Will I see it
If I drywall over it will I see it?
Old 07-02-2012, 01:02 PM   #4
Dont know. Might ask in the drywall forum.
Old 11-21-2012, 12:05 PM   #5
I do realize this thread is a few months old, but I came here with the same question. What is the purpose of the Thermopan? The drywall will serve the same purpose if I remove the Thermopan? It's okay to drywall right over the other ductwork too? This forum is great. This is my first post, but I've spent a lot of time lurking.
stayinhomewith6 is offline   Reply With Quote
Old 11-21-2012, 08:31 PM   #6
Rewards Points: 582
I really dont like to see drywall for closeing in cold air....remove thermopan and cut it to recess inside the joist seal it good ...then drywall ben sr
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
