Drywall\duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 03:12 AM   #1
Rewards Points: 83
drywall\duct work
I had a neighbor that has been doing construction for 30 years tell me that the "new" way they are doing drywall around duct work is to screw the drywall directly to the duct work instead of framing it out in situations where headroom is tight. Is he full of it?
rodsteryz is offline   Reply With Quote
Old 01-04-2010, 04:53 AM   #2
I can say I've seen it done, but it's not a good idea. Duct work is not a structural element and shouldn't be used to support drywall.
jerryh3 is offline   Reply With Quote
Old 01-04-2010, 06:42 AM   #3
An old Tradesmen
Rewards Points: 6,892
Its a code violation here.
Duct work is not a structural support rated product.
Maybe thats what he does on side jobs to cut cost.
Old 01-04-2010, 01:23 PM   #4
I have been involved in the HVAC industry for almost 15 years total.
First of all...ALL duct work should be insulated, either for heat loss or to prevent condensation (which could cause water damage). Second, I would check with my local (government) Mechanical Inspector, sounds like a code violation to me. If head room is a problem, then a “fur down” (other names-drop ceiling or soffit) should be constructed and the duct ran within that space.
If you are being told that the duct size is too large and that this is not possible, you may have a HVAC designer that is really a “duct jockey”. NOT ALL air flow problems should simply be solved with a larger duct. The answer may be a second furnace/air handler. Sometimes, it basically comes down to: “do you want to do it cheap or do it right?”
apache505 is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 07:28 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
duct work framing kama Carpentry 4 11-15-2008 12:40 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 08:47 PM
