Old 11-28-2012, 12:43 PM   #1
SuperJETT's Avatar
Dryer venting options
I'm moving the washer/dryer from the basement up onto the second floor in a storage room/hallway/whatever you want to call it.
The interior wall is the plumbing wall for the full bath that's on the opposite side, so the washer goes there easily. There is room for the dryer beside it, but since venting a dryer up an interior wall is a no-no, do I have any options? I can go up 6' and back 6' to an exterior wall to vent it outside but is that ok?
The other option is to put it on the other side of the room on the exterior wall but it would throw the layout off quite a bit and switching laundry from washer to dryer would be a stretch.
Here's a quick sketch of what I'm working with. I basically have 3 positions for the 2 appliances. The washer has to go in 2 or 3 and the dryer in any of them. The bottom exterior wall has an angled ceiling from the roof starting around 4' up. The steps go downstairs. The door on the left leads to a bedroom/bathroom.
Am I limited on the venting setup due to distance? I have no problems with a duct being visible going up/over the steps, this is not in a 'public' part of the house, the back steps are rarely used and the door will normally be shut. I would run it in rigid duct, not flexible.
SuperJETT is offline   Reply With Quote
Old 11-28-2012, 01:01 PM   #2
SuperJETT's Avatar
After searching for the right terms, it appears I should have no problems going up and out the back wall above the steps with rigid duct. I'll be well within the distance limits and be able to have both washer/dryer next to each other and do our hanging rod and folding table in the room as well.
Old 11-28-2012, 01:05 PM   #3
What does your dryer manual say is the maximum developed length for the exhaust??
Check this out also:http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Dryer venting options-new-bitmap-image.jpg   Dryer venting options-new-bitmap-image2.jpg
hammerlane is online now   Reply With Quote
Old 11-28-2012, 01:19 PM   #4
as long as there is a 2 inch or bigger drain line in the plumbing wall you will be fine. if there is only a lav you might find only an 1-1/2 line there which is too small for a washer.
Old 11-28-2012, 01:20 PM   #5
SuperJETT's Avatar
It's 3" for the toilet and 2" for tub/vanity, that's all fine and not a concern.
vent options for electric dryer jtimian HVAC 2 07-01-2011 03:11 PM
Vertical dryer venting oatlord Appliances 4 04-04-2011 02:26 PM
Venting A Dryer Adam9182 Building & Construction 2 10-23-2010 09:14 AM
venting bathroom fan and dryer together? merriam HVAC 3 09-20-2010 08:27 AM
Venting bathroom through dryer? phantoz HVAC 3 09-08-2007 12:53 PM
