Dryer Vent - Tape/Sealant? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 11:13 AM   #1
I had the dryer vent out through a basement window, but I am replacing the window. I drilled a whole through the ledger board (right above the sills). The total run is a bit more then 4 feet. Little curve to it. Does it look ok?
And...
The clamps don't seem to tighten the seems enough. What is the correct type of Duct Tape to use and or sealant? (I know it's not the HDepot grey kind)
Let me know.
Thanks,
Coop
Dryer Vent - Tape/Sealant?-dsc01758.jpg   Dryer Vent - Tape/Sealant?-dsc01759.jpg
coopns is offline   Reply With Quote
Old 06-15-2012, 05:10 PM   #2
Rewards Points: 616
i prefer solid pipe not flexible but its o.k.... foil tape is what you want ...no screws
carmon is offline   Reply With Quote
Old 06-15-2012, 07:56 PM   #3
I would use aluminum tape on the hard pipe to hard pipe joints, but use a clamp on at least one flex to hard pipe joint so you can take it apart and clean it.
TopTechnician is offline   Reply With Quote
Old 06-16-2012, 08:03 PM   #4
Rewards Points: 160
silicone and aluminum tape. silicone holds it in place and the tape seals it off
jhack836 is offline   Reply With Quote
Old 06-17-2012, 06:06 AM   #5
Rewards Points: 1,216
I also prefer solid pipe with elbows and foil tape and bands no screws.
COLDIRON is offline   Reply With Quote
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 12:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 06:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 01:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
