Dryer Vent Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 11:37 PM   #1
Rewards Points: 85
In a 34-year-old house I have a dryer vent located just above floor level on the first floor. It goes into the interior wall, immediately makes a vertical 90 degree angle turn between two walls, then rises about 8 feet to the chase between the first and second floor, then makes a horizontal 90 degree angle turn and runs about 20 feet to the exterior of the house where it exits. In other words, it goes in, then up, then out. The problem is there is a break somewhere along the line so that the exhaust never exits the house, which, obviously, has resulted in moisture problems.
My question is: Is there any way, other than tearing out drywall walls or ceilings, to remove the old venting and install new venting? Specifically, I'm wondering how to fish new ducting through these turns. If that is not possible, how can I remove & replace the ductwork and minimize the drywall work I'll have to do?
Thanks.
Update: I have already snaked the venting & it is clear.
janralix is offline   Reply With Quote
Old 08-29-2010, 11:41 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
is there not a more direct route to the outside? thats a long run of duct for a dryer
Tom Struble is offline   Reply With Quote
Old 08-29-2010, 11:48 PM   #3
Rewards Points: 85
Unfortunately, that is the most direct route.
Old 08-30-2010, 06:42 PM   #4
sktn77a's Avatar
Rewards Points: 388
Theoretically, you can "blow" a flexible fabric pipe in there and then inject a hardening resin to give it shape inside the existing duct (used mostly for leaking drains). Don't know how well this approach would work for a dryer vent, though.
sktn77a is online now   Reply With Quote
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 09:26 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 11:39 PM
Dryer Vent replacement biggie12 Appliances 8 07-22-2010 04:06 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
