Old 03-12-2008, 09:47 PM   #1
Dryer Vent Question
Hello. I am hoping that someone can give some advice on running a dryer vent to the outside of my house. The previous owner vented the dryer into the garage, which appears to be putting a lot of moisture (and lint) onto the wooden structure of the garage roof. I plan to undertake a project to run the vent to the outside. Would it be better to go straight up through the garage roof above the current dryer vent (about 12 feet), or to the side of the house, which will require going through one interior wall, a closet and an exterior wall? My house has cedar tongue and grove siding.
jlaky2000 is offline   Reply With Quote
Old 03-13-2008, 01:32 AM   #2
Dryer Vent Question
Just know where your studs, any electrical, and plumbing are. I have cedar shake and put my vent through the side of the house, with about a seven foot run. No ladder work, and you just need the right hole saw and some paintable caulk for your dryer vent. If all you have is a straight shot through drywall, plaster lathe, insulation, and siding, this is a good way to go. There are maximum dryer vent lengths here: http://www.applianceaid.com/vent-length.html
You'll have to pull the roofing back (shingles, felt paper, etc.) if you go up, so you can install proper metal flashing, black felt roofing paper over that, and then redo your your roof shingles. I had to do that with a leaking pluming vent, and it was a lot more work than the dryer vent. I also used some roofing tar.
Mike
Mike Warner is offline   Reply With Quote
Old 03-13-2008, 09:22 PM   #3
Dryer Vent Question
Thanks a lot Mike. I was worried about taking the "easy" path up to the roof.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
Ridge vent question dpreznik Roofing 7 04-13-2007 04:03 PM
Roughed in basement vent question jeffgator Plumbing 5 01-27-2007 12:48 PM
