Dryer Vent Material. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 05:06 PM   #1
Rewards Points: 49
dryer vent material.
can I use 4" PVC for a dryer vent?
Will that fit up with the plastic dryer outlet baffles they sell that mount to the outdoor surface?
I bought steel ducting and the any angle 90's. Should I stick with steel?
I can wrap it in reflective bubble wrap.
4" PVC O.D. is not the same as 4" duct in terms of diameters? SO im not sure it will work plus fitting it up to the short flex portion from the dryer may not work.
I am hooking this up in my crawlspace (not that it matters)
john_bry is offline   Reply With Quote
Old 11-27-2012, 05:21 PM   #2
Rewards Points: 1,216
Most people use 4" round galvanized with segmented ells. Make sure the crimped ends are installed in the right direction of flow and only use tape on the joints no screws. Stay away from PVC, Plastic and metal flex duct. Flex catches lint and dirt.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Floor dryer vent won't allow enough room for dryer kay-d Appliances 4 07-13-2012 03:09 PM
Dryer Vent Leaks Water glennonr General DIY Discussions 9 04-23-2010 07:50 AM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 12:26 AM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
dryer vent connecting material Alan HVAC 7 08-31-2008 05:42 AM
