Dryer Vent Ducting - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 12:11 PM   #1
Landlord
Rewards Points: 89
Dryer Vent Ducting
Going to have a rigid 4" Dryer vent inside the wall. Do I need to worry about it getting to hot? There is going to be insulation up against the pipe and drywall. Should I clear out the insulation? Thnks
cocean is offline   Reply With Quote
Old 08-08-2009, 12:41 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
I doubt it but I would talk to your local building and mechanical inspector. More out of concern for liability issues. It is possible for a dryer to stick on and overheat but it is rare.
Old 08-08-2009, 02:20 PM   #3
Registered User
Rewards Points: 5,212
I second to run it by your Building Inspector: Clothes Dryer
�� Install appliances per manufacturer’s instructions. (M1307.1 & G2408.1)
�� Clothes dryer exhaust ducts of metal with smooth interior surfaces. (M1501.1 & G2439.5)
�� Connector not concealed in construction. (M1501.1 & G2439.5)
�� No screws used to attach connector to duct. (M1501.1 & G2439.3)
�� Duct connector 4” minimum or appliance outlet size. (G2439.5)
�� Exhaust duct doesn’t exceed 25’. Deduct 2.5’ for each 45-degree elbow and 5’ for each 90-degree bend.
(See also manufacturer’s installation instructions when make and model of dryer are known at rough in.)
(M1501.3 & G2439.5.1)
�� Clothes dryer ducting run independently of other ducted systems. (M1501.1 & G2439.3)
�� Exterior termination is backdraft damper with no screens. (M1501.1 & G2439.3)
�� Dryer duct connector maximum 8’ long. (G2439.5)
�� Gas dryer gas connectors maximum 6’ long. (G2422.1.2)
A sample code, yours may be different.
Be safe, G
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Dryer Vent Cleaning handy man88 HVAC 1 01-07-2009 04:08 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
