Dryer Vent Connecting Material - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2008, 10:14 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
dryer vent connecting material
to connect the metal piping together for dryer vent, is it acceptable to use metal tape?
Journeyman Plumber
Old 08-28-2008, 01:28 PM   #2
if you are talking about...
those extremely shinely sticky alluminum tape... not only it is ok to use those... should use those and don't know what else you can use...
those plastic duct tape is not suppose to be use for connecting duct.... why they being call "duct" tape then... go figure...
KUIPORNG is offline   Reply With Quote
Old 08-29-2008, 05:46 AM   #3
oops, did I do that!
By code, no. Metal duct must be connected with a minimum of 3 metal screws per joint. The seam can be sealed with foiltape to reduce leakage, but cannot rely soley on the tape.
Hows everything over in the plumbing section?
8 Ball is offline   Reply With Quote
Old 08-29-2008, 11:54 AM   #4
screws yes...
yes need to screws... I kind of forget it... and take it as already take for grounded... even I did my basement.... yes the metal tape only for sealing to avoid heat lost...... if solely by tape is no good.... you can do it easily if you use self drilling screws and a good cordless driver...
Old 08-29-2008, 03:55 PM   #5
30 year tech
hvac122's Avatar
Guys, he's talking about a dryer vent here. Our code will not let a dryer vent be connected with screws as they will collect the lint and make it impossible for future cleaning. If we use screws it will fail inspection.
We use the foil tape to join and then make sure the pipe is strapped down good so it will not move.
hvac122 is offline   Reply With Quote
Old 08-29-2008, 04:01 PM   #6
gee... my dryer vent is not right then...
I did mine with screws.... now you talked about this I think it make sense not to use screws....
in our area... either such code does not apply... or the 2 minutes inspection from the inspector miss that....
welll... what is done is done.... I will investigate if there is such problem ..... so far it is still good no problem.... after more than a year of usage...
Old 08-29-2008, 04:19 PM   #7
BUILDER / REMODELING CONT
buletbob's Avatar
agreed!!
Old 08-31-2008, 06:42 AM   #8
Shucks..."foiled" again.
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Flexible gas line and dryer vent? kcrossley2 Plumbing 5 05-05-2008 12:31 PM
Dryer vent and AC compressor - min. distance? RDS HVAC 5 05-04-2008 07:50 AM
Dryer Vent Question jlaky2000 HVAC 2 03-13-2008 09:22 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
