Dryer Vent For Cold Climate - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2015, 08:01 PM   #1
Rewards Points: 640
dryer vent for cold climate
last year I literally had our dryer vent pipe turn to ice, the flapper outside just isn't cutting it no mater how much I clean it... so it's letting outside air in through it...
What is the best dryer vent now days? the dryer is literally on the same wall as the vent, so distance to it isn't an issue, unless 2 - 3 ft of pipe is an issue ha...
I've seen a bunch of places recommend ones like in this picture
http://www.bz1-img.com/images_custom...13980_full.jpg
would that be the best air sealing way to go?
also, what's the best way to seal he pipe through the wall? because air seems to leak in... the builders just cut a 4 1/2" hole in the wall and out the exterior sheathing, just foam around it?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 09-26-2015, 08:30 PM   #2
An old Tradesmen
Rewards Points: 7,332
The Canadian guys will probably be the ones that know how to deal with it the best.
Old 09-26-2015, 09:20 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
The basic aluminum vent with a flapper works for us. If the flapper is not seating then it is warped or damaged or got lint on it and not seating. Never had a complaint about them freezing. You would also need quite a negative pressure in the house to suck air in and freeze. Silicone works fine around the edges. May need to be replaced after a number of years so buy the most expensive kind which lasts longer.
http://www.homedepot.ca/product/ez-a...-4-inch/964097
Old 09-26-2015, 09:23 PM   #4
Rewards Points: 7,678
foam is fine for sealing around vents indoors. outside the uv will damage it.
try to source a metal vent; the plastic gets brittle and snaps after years of uv exposure. some plastic vents may last longer than others.
plastic is only used because it's cheap.
user_12345a is offline   Reply With Quote
Old 09-26-2015, 10:36 PM   #5
Rewards Points: 3,764
The one Yuri mentions is the one I use (for the bathroom vent, drier vent and the stove vent as well). It does freeze shut like most do but thaws and becomes operational pretty fast after you start the dryer.
You don't want that vertical thing you're looking at. It'll trap water and freeze more solid as a result.
Bob Sanders is offline   Reply With Quote
Old 09-27-2015, 08:31 AM   #6
Rewards Points: 640
thanks, the one that is there now is a vinyl siding one, basically all plastic..
as for foam, do I have to use the red foam for heat contact or is it not up to that requirement since it doesn't get hot enough? (just have to check, since I'm not sure of what temps you have to change from normal foam to the fire stop foam)
Old 09-27-2015, 12:12 PM   #7
Rewards Points: 1,250
Keeping the lint cleaned from the mechanical parts is paramount and after the clothes are dried as dry as they can possibly be remove them and run the dryer another 5 minutes.
Dryer Vent through Rim Joist Branden Building & Construction 5 09-26-2012 11:55 AM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 06:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
