Dryer And Bathroom Fan Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 02:14 PM   #1
Dryer and bathroom fan venting
Hi, This is probably a pretty basic question but HVAC is not my world so pardon the ignorance. I was helping a friend with some small issues around his condo and noticed a lot of condensation around his bathroom ceiling light/fan combo. When I pulled it down we found an incredible amount of lint. So much so that it would appear that it's from the dryer? I'm guessing that they run the fan while the shower is in use and because of the lint, the moisture isn't really going anywhere. When the fan is running it doesn't seem to be pulling much air. My only experience with clothes dryer vents is in basements when it vents out of a short <4' length to the outside. This dryer is in the middle of their unit and likely in line with the bathroom (which is at the outside wall) fan. Is this correct? Offhand I don't recall seeing any lint trap other than the one on the dryer itself. This is 100 year old complex but all of the units have roughly the same set up and layout. Thanks for any input.
Matt Tennessen is offline   Reply With Quote
Old 02-26-2012, 03:32 PM   #2
Rewards Points: 636
first run dryer and see if you feel hot air out of bathroom fan to make sure they are not coonect most likly they are not. the lint is probaly dust i one time got a complaint about exhuast fan not working and wanted it replaced so i removed fan cover to see if vent flap was stuck was not it so i looked down vent pipe and i found a gallon or more of water in vent pipe come to find out there was a big sag and the moiture they were sucking out of bath then traped in vent turning back into water clogging vent do not know if your friends situation is the same but thought it could be something to read
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
combining dryer vent with bathroom exhaust fan tibo613 Plumbing 2 11-06-2010 09:36 PM
venting bathroom fan and dryer together? merriam HVAC 3 09-20-2010 07:27 AM
Can bathroom exhaust and dryer share same outside duct? benze HVAC 17 09-08-2010 02:24 PM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
Venting bathroom through dryer? phantoz HVAC 3 09-08-2007 11:53 AM
