Dropped Glue Bottle (capped) In Return Duct. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 02:17 PM   #1
Dropped Glue Bottle (capped) in return duct.
I accidently dropped Gorilla Glue bottle (cap on it) in the return duct on Second floor. It is stuck there and sure it's harmful... How can I take it out from there!
shunail is offline   Reply With Quote
Old 08-13-2012, 02:23 PM   #2
How far down is it? Can you see it? Can you access the duct from below?
Post a pic.
You might be able to get a stiff wire bent into a hook under the bottle and slide it back up the duct wall till you can reach it.
If its not restricting the flow a lot I might consider leaving it. Eventually it will solidify in the bottle and become inert.
Evstarr is offline   Reply With Quote
Old 08-13-2012, 03:44 PM   #3
biggles's Avatar
remove the grill and coat hanger with duct tape rolled sticky side out...might grab it you'll sell the house before it goes dinasour fossel on you...but every time you go to but it again guess what oh it is still there in that return...
Adding Return Air Duct in Master Bedroom ajlewis1 HVAC 10 08-14-2011 05:33 PM
Should I seal return air duct? phareous HVAC 1 11-13-2007 12:14 AM
Humidifier in Return duct TurningColorz HVAC 2 10-29-2007 06:59 PM
Central Air return duct location backpacker2 HVAC 3 05-28-2007 11:07 AM
Heater Return duct - Moved to HVAC forum backpacker2 HVAC 1 05-16-2007 12:30 PM
