Dripping Range Hood - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 09:09 PM   #1
dripping range hood
Hi everyone;
We recently had a new range hood installed and vented to the outside (hooray!)
Unfortunately all winter whenever we cook we have condensation dripping...
The initial roof cap that was install was probably 3 feet high! and in the first cold snap boiling water caused a downpour! The contractor came back and changed it out - to something that is about 16 inches high and added a second damper, and while it no longer pours, we do still get drips. Contractor says the pipe was insulated in the attic
Should the roof cap be that big? When i look on HVAC supply sites everything is very small...
Are there any suggestions for stopping the drip from condensation in the range hood? Or links to what the roof cap SHOULD look like?
The vent goes straight up, slightly sloped roof...
Thanks!
curlsmm is offline   Reply With Quote
Old 01-24-2012, 09:14 PM   #2
Rewards Points: 14,026
Why are you taking his word for it that it's insulated in the attic. Just go look.
Old 01-24-2012, 09:30 PM   #3
how
Rewards Points: 1,104
What size duct does your kitchen fan instalations recommend compared to what you have?
Do you know if the attic portion of that duct is properly insulated or have you only got the contracters word that it is?
If the vent sizing & insulation looks OK then an internal drip catcher, 1" above the roof line that is drained down and out to the roof might be an answer. It is basically a low profile circular gutter inside the vent that guides the condensation to a downward facing drain hole.
how is offline   Reply With Quote
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 02:43 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
