Dripping Condensation (all Over My Floor) - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 04:54 PM   #1
Dripping condensation (all over my floor)
I have dripping water from the joint where the PVC condensation drain connects to the body of the (indoor) HVAC unit. On the Carrier FV4CNF003 I have, that joint is just below the horizontal filter. See below for the close-up (not the stream of water) and the fuller image. Any thoughts?
maxman10 is offline   Reply With Quote
Old 07-28-2012, 05:42 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
cut drain - remove male adapter and make new drain and use teflon tape and or thread sealant when reinstalling.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-28-2012, 05:43 PM   #3
The drain pipe may be clogged. The problem is you don't have an opening to clean the pipe. Needs to create one. the top of the P-trap will be a good spot to create an opening.
clocert is offline   Reply With Quote
Old 07-28-2012, 07:40 PM   #4
Rewards Points: 582
yep get an opening to clean out drainline...could be clogged... change that 90 at top of trap to a tee....
Old 07-28-2012, 09:23 PM   #5
if you can access the other end of the drain (where it terminates) a shop vac can be used to suck out the clog.
turnermech is offline   Reply With Quote
Old 07-28-2012, 11:42 PM   #6
Rewards Points: 271
Yup. Go outside and hopefully you can find where the condesate pipe drips out. Put a wet vac on it. You may want to put your hand there so you have 70 to 80% suction. Take the vac off as soon as it unclogs.
FrankL is offline   Reply With Quote
Old 07-29-2012, 07:10 AM   #7
Thanks for all the suggestions. I did drill hole in the top of the elbow and put my fish tape down through to try to unclog it. It seemed to help, but I will check the progress today to make sure that it worked - the wet dry vac is also a great idea
Old 07-29-2012, 07:57 AM   #8
This can cause issues as well with a pull-through air handler like yours. As others have said, replace the 90 directly on top of the trap with a tee, and then add a short piece of pipe on top of that Tee, and cap it off. This will allow the system to maintain the correct pressure on the drain system, and also provides you with a cleanout system for the future.
See the image below.
scottmcd9999 is offline   Reply With Quote
The Following User Says Thank You to scottmcd9999 For This Useful Post:
ben's plumbing (07-29-2012)
Old 07-29-2012, 11:10 AM   #9
Rewards Points: 271
Lowes and probably other places sell the little blue chlorine or unblocking tabs to clear out gunk. My A/C guy for my office A/C's says you can put a cap fill of bleach in there for a cheaper solution too.
He actually is not crazy about wet vacs. This is why I said use your hand at the pipe to keep the vac from pulling 100% suction.
Old 07-29-2012, 11:17 AM   #10
primary is clogged, as mentioned several times before
also if you don't like your floor getting wet (should it clog again), run the secondary drain somewhere (the 3/4 fnpt fitting directly to the left of where the PVC is coming out) where you will notice it, but won't care if it gets wet.
Or get a "EZ Trap" (google it). It will replace your current trap and provide a clean out T (as mentioned earlier) and it has a float switch to automatically turn off your a/c if it clogs. So if your A/C stops working, just go look at the trap (the EZ trap is clear, making it easy to identify clogs) and see your new present
danhr is offline   Reply With Quote
Old 07-29-2012, 12:16 PM   #11
biggles's Avatar
24" piece of hose garden/or clear plastic insert it into the open within the pan wrapped with a wet paper towel and...blow on it....but that trap needs to be redone
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 09:01 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
