Old 07-01-2009, 04:53 PM   #1
Default Drip pan leak
Hi,
So I wake up this morning to find a small amount of water damage on our ceiling. It appears there is a small leak somewhere in the rather large drip pan (~2'x4'). The supporting board is wet as is the insulation where the water is leaking though. The pan also looks to be slightly warped so water is proabably not exiting the drain as efficiently as it should.
I am sure this is a stupid question but I was wondering why it's not possible to connect the drain directly to the drip pipe or catch the drip in the drain? Why is it necessary for the water to go into the pan first?
I was hoping as a temporary solution until we are ready to replace the unit to bypass the pan altogether. Of course the pan should be replaced but a very large unit is sitting on top of it and it looks like a huge pain in the butt to fix.
bbfan23 is offline   Reply With Quote
Old 07-01-2009, 08:26 PM   #2
biggles's Avatar
if the pan is under the air handler it is considered the emergency pan and the main condensate is blocked on the line or clogged within the unit.there never should be water in that pan....check the inside of the air handler you will see a filled condensate pan with water in the insulation under the fan
Old 07-01-2009, 08:39 PM   #3
Tired & Dirty
agreed biggles, prolly the safety pan drain blocked also, if there is one, most the time we run the overflow drain, & emergency pan drain in front of a window or door so the homeowner can see(or feel) it dripping and know something is not right. sounds like they are going to be doing some drywall repair and painting. Hate air handlers in attics for just this reason, but no choice sometimes. :o(
evapman is offline   Reply With Quote
Old 07-02-2009, 12:42 AM   #4
Whose job is it to run these lines? A plumber, or does the HVAC guy run the lines too? It's not easy to run pvc around an attic with the proper pitch into a soffit.
handy man88 is offline   Reply With Quote
Old 07-02-2009, 01:06 PM   #5
Tired & Dirty
Handyman 88,
Around here the HVAC guy uausully run them hopefully when installed the 1st time new, but as you stated it is a itch after the fact to run them. In some of them we have put a condensate pump in the safety pan, easyer to run the 3/8" line to somewhere noticable.
Old 07-02-2009, 08:36 PM   #6
Wish I had known for the past 10 years that water was not supposed to be dripping outside! We had never seen/heard it go elsewhere so I just assumed it was normal. Unfortunately with water sitting in the drip pan off and on for that long it has rusted through and created a slow leak.
So I called someone out and they unclogged the line and managed to create a bigger hole while showing me how bad the pan was which in turn really let the water out. Thanks, I really didn't need you digging your finger in the pan to point out the obvious. The smell of wet wallboard reeks in one room now.
Anyways now that I know how to keep the main line clear I don't anticipate any more secondary pan problems. I will either put a small bucket under the second line and keep an eye on it or (unless someone can tell me otherwise) reconfigure the pvc connected to the pan and run it directly to the second line.
Replacing the giant pan which the blower sits in looks like a big job (he said it's not worth doing unless they replace everything) and will not likely happen until the unit needs to be replaced (1996 Lennox).
Thanks for the input.
Old 07-02-2009, 09:03 PM   #7
biggles's Avatar
the secondary pan on other installation is piped out seperate from the unit drainage piping and run over a kitchen window or onto a front stoop so if you see water dripping you know the pan inside the air handler is bloocked...let ir dry out and coat the leaking area with liquid plastic from Home Depot find it in the tool section for redipping handles on tools.it will seal the holes.....paint it on with a cheap paint brush
Old 07-03-2009, 07:14 PM   #8
Why not just use waterproof caulk?
Old 07-03-2009, 08:41 PM   #9
I may try to fix it but it is a very big pan and the back side is impossible to get to to inspect for cracks. Seems to me the easiest fix is to connect PVC directly to the overflow pipe and run that outside. Nobody has really commented on that as an alternative and (to me) an immensely easier fix.
Old 07-03-2009, 09:09 PM   #10
An old Tradesmen
Secondary drain pan is a code requirement.
You can pipe boh the primary, and secondary drains of the A/C seperately to the outside.
When you see water coming out the secondary line, you know to unclogg the primary.
More On This Topic
You may notice sometime that water is dripping out of a tube in a place that it’s never dripped before, and it’s a pretty annoying thing and it may be getting your porch or door wet. Well, there’s a reason for that. It’s called... Read More »
If you smell a gas leak, it’s imperative that you locate the gas leak and shut off the gas and have it repaired. And it’s very easy to locate the source of a gas leak. Just use some dishwashing liquid and some water - about a half and half... Read More »
Hey everybody, Don Golden here with Expert Village coming to you from my shower. What are we doing in here? I'll tell you what I am doing. I've got a little leak going on and I should be a little bit of an expert on this, fixing showers, fixing leaks... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be showing you how to inspect for leaks. There is a couple of areas that needs check for leaks first is at our connection point on our water shut off where the hose meets that water... Read More »
I'm Cathi Pare, water resource specialist in the city of Santa Barbara speaking to you today with expertvillage.com. We've done our water check. We've determined that we got a leak somewhere from the house out. It's not in the supply line by shutting it... Read More »
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 08:06 PM
Intermittent leak Kap Plumbing 1 05-09-2009 11:02 PM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 10:18 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 04:10 PM
Furnace Drip!??! acawley22 HVAC 1 01-10-2007 10:36 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
