Drip In Fridge - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 08:31 PM   #1
Drip in fridge
Hi, I have a Gibson model # GRT17G4A fridge....In the fridge itself there's a covered "thing" on the top wall blowing in cold air. Problem is,there's a constant drip coming off it. I don't know if it's condensation or what,but I'm sure keeping a sponge in the fridge is not the fix! Can ya help?
waynewkappler is offline   Reply With Quote
Old 04-15-2011, 06:42 PM   #2
hillbilly guru
Send a message via Yahoo to hvacguytn615
i have not worked on a gibson frig but on most other brands you would most likely have a slow drain when the unit goes into defrost some of the water come down through the air duct on otjher brands there are screws in the back panel inside the freezer compartment remove the panel there will be a tube about three eights a round poor a few cups of hot water down the tube this should clear the drain if its like other brands hope this helps
hvacguytn615 is offline   Reply With Quote
Old 04-18-2011, 02:06 PM   #3
Drippy fridge
Thanks Hvacguy! Seems to be workin fine!
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Water buildup in Fridge mibson Appliances 14 12-05-2013 10:02 AM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 01-01-2009 12:08 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
Drip Cap or Drip Rail joe3534 Roofing/Siding 7 09-18-2007 04:38 PM
