ok! I need to drill through, what appears to be, block foundation to create a hole for a dryer vent. The reason I say "what appears to be" is due to me not knowing exactly what kind it is. It's block but not smooth, somewhat beveled and stuff and definitely NOT stone (I hope). The only home renovation I've done so far is gutting a bedroom, installing new electrical, and drywalling it so I have some concerns especially when it deals with what is holding up my house! Back on topic...the block is a good 8-12" wide and I was wondering if I can just drill through it with a masonry bit and punch out the hole without my whole house coming down:whistling2:. Where, on the block itself, should I drill (middle I assume?!?!?). If anyone has done something like this, please give pointers! Thanks.
If we are talking about a standard 8x8x16 cinder block then the easiest is to drill out one side as the center web will be in your way. I would not worry about your house coming down as several blocks are usually removed to make way for most basement windows.
hey thanks! but just outta curiosity(I'm not questioning you), will there be a rebar in there or will I just somehow blast right through that? the house was made in the 20s-30s I believe.
I really considered that, but, you're gonna love this, the wood framing right above the block is surrounded on the outside by 2-3 feet of excess siding. I know it sounds crazy but it's very hard to explain. I would love more than anything to go through wood instead of stone but I guess we'll just see what happens. Thanks for the tip!
If you are truely going through block (and not stone) do yourself a favor and go to Home Depot and rent a Hilti hammer drill. (If you don't have or can't borrow one.) They rent you one hole bit and a chisel bit. My cost was $34.13 total for a 4 hr rental including 'insurance'.
Made short work of routing a dryer vent through brick!
Sorry dac, no Hilti performance for $40! I have a Chicago hammer drill and tried that for hours until I gave up and went to HD for the rental. The Hilti did each hole in less than 1/10th the time. I guess that's why they cost $400.
V;
the insurance was on the tool for any damages I may have done to it. It was about $3. Didn't realize it was optional when renting, but I was running out of daylight and in a rush. I'd decline in the future but not losing sleep over $3. Wish I could have insured the brick front house when thinking about this job. There is a lot of pucker factor when you start boring holes in the brick front of your house! But, thanks to some advice I got here, it all turned out great!
Matt;
For my job I needed to go through a single course of red brick. The brick is not structural, but a facade on the front of my house. About 3 1/2 inches thick total, but solid brick.
I think dac is giving good advice to aim to the side at the 1/3 point of a block (so as to avoid the center web) if you are dealing with something like standard cinder block. That should give you a a much easier pass through than all solid material.
One more clarification; I'm talking about the method where you drill a bunch of small (3/8") holes in a circle and then punch out the 4" hole with a chisel.
exactly what I meant. I'll try to get pictures up later and hopefully the USB monster didn't come into my house again and steal my cords:laughing: EVERY FREAKIN TIME lol
Yes, most of the holes are drilled from the outside, but the centering hole is drilled from the inside ( in my one-time experience) to match your vent orientation.
And I think it would go without saying, but a 4" dryer vent needs a 4 1/2 " hole for clearance.
I used a 4 1/2 " hole saw to go through the inside drywall and then the plywood sheathing from the inside, and then drilled a centering hole through the brick from the inside.
From that center, I plotted the numerous holes in the brick and mortar to be drilled from the outside.
Like I said, scary the first time you do it, but it works!
sorry about the last post^^^(thought that was the last one and I wanted to answer their post:laughing...anyways, yea, I considered that(there's a post in there somewhere) and I guess it would be easier to do that. I've stated before that the reason for me being against that was the overhang of the house but after looking at it, I suppose this would be the better alternative especially due to others feeling that it would be a better choice. What sucks is that the siding is "brick" and either way, I'm gonna have to do some masonry work lol...can I ever win?!?!?
that makes even more sense! thanks. I'll just talk it over with the hierarchs and hopefully get down to business soon. unfortunately, snow won't be a problem seeing as we'll never get another snow as good as the one we just had, well at least in the next 2-3 lifetimes lol
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
