I don't know the codes in ny, but i imagine they are pretty close everywhere...i have never heard of this...in virginia, drains are run outside, close to the ground..it is a good idea to have an "emergency" pan with a seperate drain in case your ac becomes clogged...usually these aremore noticeable so you'll see when you have water coming from them..
Originally Posted by Scott_K
I recently had a 2 zone A/C system installed. It has 2 units in the attic with a drain line out of each one. I was told that in order to pass an inspection, I had to have the those 2 drains converted into 4 drain outlets that lead into the gutters. Is there a reason for this ?
TIA
