Old 05-02-2006, 07:16 PM   #1
Drainage from air handler
Hey......I have a Trane unit.....the handler is in my laundry room.....there are three openings in the air handler.....one on the right is round and is plugged.....the middle opening is 3/4 and has pvc pipes for drainage from the handler.....the problem is the third opening on the left.....its a strange looking oblong fitting and I am getting drainage from it......I have owned the house for two years and had no problems before......can anyone tell me what my problem could be......thanks so much.......
jack B is offline   Reply With Quote
Old 05-07-2006, 09:35 AM   #2
coolmen's Avatar
Some evaporater coils have up to three points to connect a drain to.for the purpose of flipping the coil around for a differant applications and useing the correct hole to drain. Not sure but is where it is leaking water another plugged area that simply needs to be tightened a LITTLE to stop this leak. keep in mind that a clogged pvc drain,dirty air filter or low on refrigerant would cause the evaporater to ice up and cause water to drip from around the drain pan.
coolmen is offline   Reply With Quote
More On This Topic
Hi, my name is Mark Delgado with American Auto Service for Expert Village. Today, we are going to talk about what the problem is with the air conditioner. We found that the compressor is no good, it has internal problems. You have to unbolt it from the... Read More »
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
A boat leak can cause expensive damage to your boat and all of the items that you keep in it. It's important to quickly plug your boat leak to avoid further damage to your boat and to keep water out. Follow these instructions to help you identify the... Read More »
Hi my name is Mark Delgado with American Auto service for Expert Village. This is another diagnostic tool that could be used with It's an ultra violet light dies easily in most freeon oil. So when you charge you're system up and you're going to add oil... Read More »
Air Compressor Maintenance
Air Compressor Maintenance by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I'll be talking about air compressor maintenance tips. Before you preform any maintenance task you first need to turn the compressor off, unplug the compressor, drain the tanks, and let your... Read More »
DIY Heat Pump/Air Handler replacement hennyh HVAC 58 02-08-2010 08:25 AM
Building a drainage ditch get outside Landscaping & Lawn Care 5 05-15-2007 03:44 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 09:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
Drainage Ditch Issues........ Alan Landscaping & Lawn Care 2 06-23-2006 12:45 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
