Drain For Uncased Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 05-16-2009, 10:03 AM   #1
drain for uncased coil
I just installed a goodman split ac unit ito my existing hot air furnace. I have 2 options for the coil drain. I could make a hole in my concrete basement floor and make a floor drain, which i would rather not do, or buy a little giant condensate pump and pump the water 20 feet away to my washing machine drain. This is my preffered method, but i am wondering if i should use rigid pvc with a trap coming from the coil, going into the pump, and output rigid pvc to the drain? Or just use the flexible tubing? Is a trap recommended with a pump? Thanks.
Yamvmax is offline   Reply With Quote
Old 05-16-2009, 11:20 AM   #2
An old Tradesmen
Rewards Points: 6,932
I prefer traps even on positive pressure coils.
Use PVC from coil to pmp. And flex hose from pump to drain.
Old 05-16-2009, 11:23 AM   #3
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
