Drain Tube On AC - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 07:15 PM   #1
Drain Tube on AC
I turned my AC on today and noticed water around the central unit. I checked the drain plug and it was clean. I took it off and the water was coming out fine. however, when I put the hose back on it did not come out. I realized that if I put on over a three foot hose the water does not drain.
I am stumped on this one.
fridge is offline   Reply With Quote
Old 04-26-2009, 07:26 PM   #2
2 things could be going on the drain is clogged up or hows the air coming out of the air handler. is it cold, warm? if so chances are the coil is froze up. if thats case turn the fan on, a/c off and let run. if that is problem your low on freon and have a leak somewhere.
damyankee007 is offline   Reply With Quote
Old 04-26-2009, 07:29 PM   #3
The air is cold coming out. Also, there is no clogging as I put new tubes on. However, when I take the tube off the AC unit the water drains fine. However, when I go over three foot long tube the water just stops draining. It is almost like we stop the flow. Take the hose off or shorten and it works.
Old 04-26-2009, 08:01 PM   #4
member
leoacrh's Avatar
make you have a good slope on the drain
leoacrh is offline   Reply With Quote
Old 04-26-2009, 08:24 PM   #5
also i agree is the pvc going down hill and do you have a p trap on it.
Old 04-26-2009, 08:26 PM   #6
I am trying. However, It comes out and then has to go five inches over to go down. That is my concern the drain is not that long. The only catch is that the if I add on to the three foot hose( already below the outlet) it just stops. I also feel air coming out of this hose. Is this correct. I would think with a drain tube there would be not air coming out.
Old 04-26-2009, 10:16 PM   #7
Shim the back of the coil.
hvaclover is offline   Reply With Quote
Replacing sink drain tube n0c7 Plumbing 7 04-16-2009 07:16 AM
condensation drain tube prablem Fixitwannabee HVAC 1 03-07-2009 10:57 AM
please help with clawfoot tub drain - obselete tube size? wombosi Plumbing 1 01-27-2009 02:26 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
