Drain Radiant Floor Loops - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 01:19 AM   #1
Hi all, please forgive me if this is the incorrect forum.
I have a slab foundation on my workshop and we have decided to winterize it for the winter due to the high costs of fuel to heat it. With that said...
My workshop floor has 6 1/2" pex loops in it and a on demand water heater to heat the water. I want to drain out the pex loops but cannot figure out how to get the air pumping into the loops accordingly. Can anyone point me in the right direction?
It is a single zone set up...
What else is needed to know enough to help?
THANKS!
About to freeze in MT
mntnvew is offline   Reply With Quote
Old 10-21-2012, 01:29 AM   #2
Basically can I do this with the recirculating system that is attached to the on demand water heater, or do I have to actually disconnect the loops from the manifold?
Old 10-21-2012, 09:12 AM   #3
Rewards Points: 13,256
Why is there not already antifreeze in the lines that would prevent it from freezing?
Old 10-21-2012, 09:34 AM   #4
An old Tradesmen
Rewards Points: 6,464
As above, it should have at least enough anti freeze already for burst protection.
Radiant systems that are drained after having been in service, usually end up with corrosion/oxidation problems when someone tries to put it back in service later.
I would check and see if it has anti freeze in it first. And if so, probably set the stat to 40 or 45.
To drain and purge all water out of it, you would need to disconnect all lines to the manifold and blow each one out separately. Along with the tankless.
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
