Drain Plug In Figidaire - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2009, 09:44 AM   #1
Drain plug in Figidaire
Hi, I have a new Frigidaire 10,000 window casement A/C and as far as I can see it does not have a condensation drain hole. Installation instructions say onlt to tilt 3/8 down in back for water to drip, also in the troubleshooting section water coming inside...tip back. Should I drill a hole? Remove one of the screws in the outside cabinet? Leave it alone? Already, in reunning it yesterday, I can see water and hear some hitting the outside fan (this noise is also mentioned in troublshooting).
Question #2: This A/C replaces an old one which was originally from an apartment and so it was framed and stuccoed through the wall. I chiseled the hole bigger by an inch or so, width wise, and now need to seal back up. Was thinking about expaning foam: probably too radical, maybe just caulk and then stucco mix?
Fred23
Fred23 is offline   Reply With Quote
Old 07-01-2009, 10:10 AM   #2
HVAC / Plumbing
Don't drill a hole... The blower wheel picks up some of the water to splash on the coils to aid in cooling
kenmac is offline   Reply With Quote
Old 07-01-2009, 11:25 AM   #3
Thanks. Makes sense to me.
Old 07-11-2009, 11:12 PM   #4
i believe.......
......in some units the water gets splashed onto the warm conser to evaporate the condensation to minimize or eliminate nusiance water dripping on other areas , imho..........Jack
psilliman001 is offline   Reply With Quote
foot lock drain plug..how to re-assemble? firsthomenewb Plumbing 1 03-01-2009 01:53 PM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 08:42 AM
Washer tray drain plug proofer Appliances 5 08-24-2008 09:53 PM
bathtub drain plug rtyui2 Plumbing 2 04-06-2008 12:43 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
