Drain Pan Over Flow Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2012, 05:15 PM   #1
Drain Pan over flow valve
I have a strange issue. Last year our AC stopped. It was called a clogged drain pain pipe.
The AC tech cut the line and put in a small rubber tube that you can see through.
It happened again this week and I went in and opened the pipe to get the air back on and noticed something strange.
See picture below. There is a slight suction on the pipe that is for drainage in the direction of the arrow. This seems to be causing the water to backup into the pan. Any thoughts on what might be the problem?
MudBug2000 is offline   Reply With Quote
Old 11-03-2012, 05:46 PM   #2
An old Tradesmen
Rewards Points: 8,170
That pipe always has suction on it while the air handler is running. Because the coil is before the blower. Its normal.
ball valve flow direction Dave E Plumbing 2 04-17-2011 08:29 AM
Hot water tank t/p valve - plumbed to drain benr Plumbing 3 04-12-2011 05:44 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 07:07 PM
