Drain Line For HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2008, 08:34 PM   #1
Drain line for HVAC
There is one drain currently on my HVAC units. there is a spot for a second one. Is it required to have this second one and what is your suggestion for routing if required. the first one runs to a sink drain in a bathroom. Appears to properly routed.
I am currently selling the house, and my inspector said it should be run. But doesn't make sense to me since the first one is run to a sink drain line ?
gray6411 is offline   Reply With Quote
Old 05-26-2008, 02:03 PM   #2
biggles's Avatar
the second trapping is not code..it is for installation options when the unit went in if the unit was slammed up against the side the exsisting is on to catch the duct work the optional connection would be used..it is either or on that item
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Installing drain line parcially upgrade. jbravo8212 Plumbing 8 02-19-2008 06:12 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 08:40 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
