Drain Hose - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 11:47 AM   #1
Drain Hose
Can someone give me a suggestion about what to do with this? It's the drain hose from my hvac unit. I've ran over it enough times pulling into my car into the garage, that it has finally cracked and leaking water, not a lot, but the usual amount you would get I guess. Does Lowes or Home Depot sell something for this, or does someone have another idea.
ws450r is offline   Reply With Quote
Old 11-05-2012, 12:05 PM   #2
Rewards Points: 14,312
Why not just run it out the back wall?
That's a really tiny hose for a condinsate drain.
Old 11-05-2012, 12:46 PM   #3
It's a cut garden hose that just drips after it quits running.
And if I could, I would run it somewhere else, but that is the closest and most convienent place to run it.
Old 11-05-2012, 02:12 PM   #4
Rewards Points: 582
why not install a condensation pump...then pump water where you want?????ben sr
Old 11-05-2012, 02:32 PM   #5
I'm just a simple homeowner that is looking for something easy. No pumps, no new hoses to the back of the house, not breaking concrete so I can bury the line, ect. I'm looking for something I can install myself that other people may have done in my situation, keep the hose where it's at, and be able to drive over it without it cracking or breaking anyworse.
Old 11-05-2012, 02:45 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
I'd say use a higher quality garden hose if that's all you're wanting to do. Nothing else will stand up to repeatedly being run over.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-05-2012, 03:27 PM   #7
Rewards Points: 616
a condensate pump is quite simple.....
carmon is offline   Reply With Quote
Old 11-05-2012, 03:31 PM   #8
Our mistake we though you might want to fix the right way not just the easy way.
Old 11-05-2012, 03:42 PM   #9
Rewards Points: 582
on my iam so sorry...thougth you wanted it fixed..... keep the hose...ben sr
Old 11-05-2012, 04:01 PM   #10
An old Tradesmen
Rewards Points: 8,236
Looks like a piece of cheap garden hose. Lowes and HD both sell low grade low priced garden hoses.
Old 11-05-2012, 06:58 PM   #11
take a 2x4 or 2x6. cut a bevel on each side of the top. on the bottom cut a groove that will fit around the pipe. replace hose with a new piece.
Old 11-05-2012, 07:16 PM   #12
Missouri Bound's Avatar
...then you get to watch it slide all over the floor.......
Do you want it your way or the right way?
washing machine drain issues lost_punk Plumbing 2 06-19-2012 10:18 AM
Washer drain hose height? yuriy128 Appliances 4 12-02-2011 05:22 PM
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
