Drain Clogged - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 08:08 PM   #1
drain clogged
I have an American Standard 5 Ton gas furnace installed in 2005. In 2007 I replaced the plumbing under the unit because the drain pipes were in bad condition. Last week we had water all over a hardwood floor and I noticed the unit was clogged again. I took the tops off the 3/4" pvc drain line and used my wet vac to suck the water, used drano and it appears to be fine now.
How do I take the cover off to look at the drain pan and coils? It is inside n my closet. So much room LOL
Model TXC060C5HPCO
larbec is offline   Reply With Quote
Old 06-21-2011, 08:21 PM   #2
vln
Underwriter
Why did you use draino near a GAS furnace... You could have blew yourself up.
vln is offline   Reply With Quote
Old 06-21-2011, 08:30 PM   #3
I used it under the unit where the drain plug is in the floor NOT by the unit
Basement drain from washer to floor drain clogged with black foul smelling mud bernice97 Plumbing 1 01-09-2011 04:01 PM
Clogged Shower Drain... possible lime built up? plenmao Plumbing 9 04-16-2010 07:08 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
bathroom clogged drain cwpetal Plumbing 2 06-09-2008 11:03 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
