-   -   drain clogged (http://www.diychatroom.com/f17/drain-clogged-108404/)
larbec 06-21-2011 08:08 PM
drain clogged
2 Attachment(s)
I have an American Standard 5 Ton gas furnace installed in 2005. In 2007 I replaced the plumbing under the unit because the drain pipes were in bad condition. Last week we had water all over a hardwood floor and I noticed the unit was clogged again. I took the tops off the 3/4" pvc drain line and used my wet vac to suck the water, used drano and it appears to be fine now.
How do I take the cover off to look at the drain pan and coils? It is inside n my closet. So much room LOL
Model TXC060C5HPCO
vln 06-21-2011 08:21 PM
Why did you use draino near a GAS furnace... You could have blew yourself up.
larbec 06-21-2011 08:30 PM
I used it under the unit where the drain plug is in the floor NOT by the unit
