Drain On Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 05-04-2010, 09:42 PM   #1
Drain on Air handler
Hello, New the the forum here so if I do something wrong sorry... I'll fix just needing some help.
I have a, I believe, Tempstar EBV 3600 B 1 Air handler. I noticed that I was getting some water in my garage and traced it back to the air handler. After taking the lower panel off I see that the bottom pan is very full of water and does not appear to be draining. I rain a small plastic snake down the portions of the drain pipe I can access and there does not appear to be a clog. The pipe appears to have enough slop and sits below the bottom of the air handler, so I believe it should be draining. Am I missing something that I should be able to fix, or should I call someone to take a look?
rtgleck is offline   Reply With Quote
Old 05-05-2010, 05:57 AM   #2
An old Tradesmen
Rewards Points: 8,194
Got a shop vac?
Use it on the drain line outside your house.
Old 05-05-2010, 10:13 AM   #3
Thanks... I'll give that a try.
Tags
air handler , drain , tempstar
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
First Air Handler extra drain pipes...Should they be capped? ceoltoir HVAC 15 08-19-2009 08:11 PM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Air Handler Condensation drain Rickl HVAC 3 11-12-2008 09:27 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
