Old 01-10-2009, 07:16 AM   #1
draft vent motor for Duomatic Olsen HMS72-D
I have a Duomatic Olsen HMS72-D forced air natural gas furnace. I am having problems with the blower that induces draft for the burners. I do not have any PVC pipes running to or from the furnace. It was manufactured in 1985. The motor freezes up after sitting overnight. It can be moved but with a good amount of resistance. I squirt a little oil into it and it seems to run fine but I don't think I am using the correct oil, just something I had on hand. I think the bearings are no good in it. I am having some estimates for a new furnace on Monday. Any idea where I can find a replacement motor or isn't it made anymore?
sparky296 is offline   Reply With Quote
Old 01-10-2009, 08:58 AM   #2
biggles's Avatar
probably a fractional HP...Fasco motor there give us the name plate off the ID motor volts/brand/amps/frame "RPM critical" how it mounts onto the blower house check www.grainger.com or here will give you other options for a complete assembly change out http://bestbuyheatingandaircondition...gory_Code=m-im
Old 01-10-2009, 12:02 PM   #3
Hvac Pro
That furnace is obsolete and should be replaced. ROTOM makes aftermarket ventor fans if you can find someone who sells them. Try here:http://www.alltemp.ca/index.php
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 11:40 PM
Noise from boiler power vent den HVAC 2 03-03-2007 08:10 AM
Direct Vent Vs Power Vent APPY HVAC 1 02-15-2007 11:26 AM
Is my furnace a direct vent or power vent? wease HVAC 5 02-02-2007 08:55 AM
