Draft Inducer Question - HVAC - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 10:07 PM   #1
Post
Draft Inducer question
Have a 14 year old Bryant system. Noticed the draft inducer motor keeps running after the unit kicks off. Is the motor bad or is it something in the main board? Should the draft inducer run when A/C is on? Thought it was for heat only. Thanks!
hvachelp is offline   Reply With Quote
Old 06-17-2008, 03:02 AM   #2
HvacWiz's Avatar
Rewards Points: 252
No it should only run on a call for heat. you either have a bad furnace control board or my guess would be a inducer control board. (located behind presure switch box I believe)
HvacWiz is offline   Reply With Quote
Old 06-17-2008, 05:38 PM   #3
Thanks. Had the control board replaced last fall. Can I unplug it so it doesn't run all the time? Everything elses runs fine. Inside and outside units.
Old 06-17-2008, 05:40 PM   #4
HvacWiz's Avatar
Rewards Points: 252
Yes you can unplug it.
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
How do I test my draft inducer? ryansturmer HVAC 9 10-20-2008 08:41 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Goodman draft inducer fan sticking TWISTED2X4 HVAC 3 06-01-2008 09:38 PM
